Cub Cadet 123 rear end gasket
dose any one have a gasket for the rear end of a 123 that they could trace and email to me to i can make a new one out of a roll of gasket paper
you can get an impression from the housing by using blueing or grease,
or just make the gasket using a ball peen hammer. |
dose it matter if it has some extra hanging over on the inside
Is there any thing i need to do when i change the hrydo oil beside drain the oil and change the filter
ok thats what i thought just wanted to make sure not trying to carry on from outer post about the oil
Sometimes there is really a lot of crud in there, often times I clean it out the best I can and then raise the front of the tractor and wash it out with diesel fuel sprayed from a pump up garden sprayer.
| All times are GMT -4. The time now is 05:42 AM. |
