-   -   Cub Cadet 147 snow blade will it fit? (https://www.onlycubcadets.net/forum/showthread.php?t=29934)
cub14501650 02-09-2014 08:46 PM
I have 3 cubs from the mid to late 70s a 1250,1450&1650 will the above mentioned plow fut them? Thanks!:bigthink::bigthink:
Cub Cadet 123 02-09-2014 09:03 PM
Yes and no. The subframe of the 147 is for a narrow frame (NF) and the other cubs that you mentioned are all wide frames (WF). So, all you need is a WF subframe and change the blade over to it, but you might find it a whole lot easier just to get the entire blade and subframe together as they can be a PITA to change over!
