Hydro Transmission Check Valve
Hello. I have a IH made 782 that has oil coming out of the small hole in top of the check valves. Is it common to have both of the valves to start leaking at the same time? Is it possible to rebuild these valves or do they need replaced with new valves? I see used valves on eBay all the time and wonder if that way is an option. Also, see there are auto and manual check valves and wonder what is the difference. Will the manual valve work where a auto valve was used before? Thanks for any help you can give me.:bigthink:
They can be rebuilt and it sounds like your O-rings are bad. The rings should only be a few bucks. The manual ones lock up a few seconds after the tractor is shut off and require a dump lever to release or open them up, whereas the automatic ones do not lock up when the tractor is shut off--which has caused a lot of cubs to take a quick, unexpected ride down a hill to the surprise of the owners who went in to get a quick drink!:biggrin2:
Cub Cadet 123 |
You can put either valve in..... but you would have to take the tunnel cover off and push them down manually if you ever need to push the tractor. Probably best just to stick with the original style. This company here has been recommended several times on this site. Probably the cheapest you can get them for. :beerchug:
J-Mech, thanks for posting the link to the other supplier for relief valves. that's a great price.
If you are interested in new replacements and not concerned about them valves being stainless steel, then a good source for a reasonable price is:
LJ Fluid Power Inc 10118 S M 43 Hwy Delton, Michigan 49046-9602 Tel: 269-623-4150 Part No: 9500085 Auto Check Valve |
The company that Jonathan linked to will also rebuild your check valves for about half the price of a new one.
http://www.ebay.com/itm/Cub-Cadet-Au...-/320670405175 |
Machtech Direct 605 Furnace Rd. Conneaut Ohio 44030 Phone: 440-499-5813 Email: mark.machtech@gmail.com E-Bay add $35.00 each plus $4.95 shipping ($4.95 flat rate regardless of amount) That's both valves rebuilt for only $74.95 |
Ditto on the rebuilds, having very good luck with those so far. I don't see these services on his site, but he was also working on a rebuildable valve that had a tiny snap ring on the end so you could simply replace o-rings and springs yourself. I've got a couple of the prototypes around the shop.
Does anyone sell a kit for the replacement parts?
The ebay seller (links above) we are discussing at one time had kits. Just so newcomers are informed, the valves are not rebuildable to the average Joe. The end is crimped shut, and must be cut open on a lathe, the parts refurbished and then the cap put back on with a few tiny spot welds.
