Cub 1650 help!!
I replaced the carb on my 1650, it ran great, then the next morning found that it was leaking fuel. I heard that aftermarket carbs, had issues with the float needle, so I replaced it with the old one, and it solved the problem. I went to make minor adjustments at idle and full throttle and now it will not run at full throttle. It idles fine, but starts to bog down and run terrible as you increase the throttle. I swapped carbs and it does it with both. I checked the timing using an ohmmeter and it is fine. I heard someone mention that a bad condenser might be the cause? Any thoughts?? Please help.
First off, did you flush the tank? You should probably put the new needle and seat back in, make sure they are clean, and set the float height. There probably wasn't anything wrong with the new, just either had dirt stuck in the needle, or the float wasn't adjusted right.
Thanks, I will flush the tank tonight, I but to new seat and needle back in the new carb and have the same problem with the throttle. I went back to the old carb last night and had the same problem, so it cant be the carb can it? I'm at a total loss. Im going to replace the condenser tonight and see what that does?
Sounds to me like you have a restriction somewhere from the gas tank to the carb. I've had screens clogged in the tank outlet, on/off gas valve off the tank clogged and carb inlet barb clogged. Check that you have free flow of gas to the carb by pulling the fuel line to it.
Yes, it could be the carb.... if they are both plugged up. Condenser is a possibility, but being that you didn't have this problem till you started working on the fuel system, it's probably fuel related. :bigthink: |
***Outside only!!!***
Just a last resort try, but you could pull the float bowl while it's on the tractor. Try turning on the gas and manually actuating the float to see if it is flowing free, and then completely shutting off at a level float. When I hear gas coming out the intake, that usually is a bad float setting/needle, or the wrong jets. :TwoCents: |
[QUOTE=Calvins66Cub;231765When I hear gas coming out the intake, that usually is a bad float setting/needle, or the wrong jets. :TwoCents:[/QUOTE]
Jetting has nothing to do with gas overflowing the bowl. :bash2: |
J-Mech
I agree, but i am a little unclear as to exactly where the gas is coming out. I'm not positive, but if the jet were too large, couldn't it spit back and run extremely rich, as if the choke were on? It sounds like a float issue though. |
I stand corrected.
| All times are GMT -4. The time now is 12:00 AM. |
