-   -   Ideas for a plow (https://www.onlycubcadets.net/forum/showthread.php?t=28291)
VIOLATOR 11-06-2013 12:04 PM
Ideas for a plow
Howdy all,
I am fixing up my plow for my 1650. It needs a new wear bar. Does anyone have any ideas for a cheep replacement. The onest that i have found are all around $60. I called the local welding shop by me and they can get me a piece of mild steel 42'' x3'' for $20. I was thinking about going with a high molecular weight plastic but that was expensive. Does anyone have any ideas on plastic vs metal?:BB&YS:
vartz04 11-06-2013 12:46 PM
Look at my thread a few down from yours about the rubber plow edge
J-Mech 11-06-2013 12:55 PM
extrememotorworks sells them ready to bolt on for like $40
vartz04 11-06-2013 01:56 PM
and the plastic edges for like $20. They have some cool stuff.
gmbadgley 11-06-2013 09:15 PM
You can always call a heavy equipment contractor near you and see if they have any worn out cutting edges from a small dozer. that would last the life of the blade.
edw 11-07-2013 07:19 AM
blade edge
Being cheap I picked up a 4 ply tire casing cut the tread out and bolted to my blade and so far has worked good. I mounted it between metal cutting edge and blade mouldboard but had to use longer bolts
Cub Cadet 123 11-07-2013 08:05 PM
Have you tried turning unbolting it, turning it around and using the other side?
VIOLATOR 11-13-2013 12:39 PM
Thank you all for the input. I have decided to go with A mild steel blade. I got a piece of steel from a local welding shop. I painted it and used some stainless steel bolts to assemble it. I'll try to get some pictures posted. My phone is giving me problems.
