My question thread
I have a few questions.
Tractor is a January 1970 107. First question is on the generator. How do I go about checking this out for proper charging? I think something might be wrong as the gauge when running sits right under the middle mark. I have the wiring diagram for it too. When tractor runs I take my dmm and as soon as I touch the neg lead to the battery the meter gets a reading with no pos lead on battery only the neg lead. With tracto off the neg lead does not get a reading. Belt seems to be newish and tight also. |
Well....... go ahead and put both leads on the battery with the engine running. What does it read then? :bigthink:
BTW: It's normal for a DVOM to do that. |
When I do that the DMM is all over the place nothing even close to stable
Try a different meter.
If your tractors battery stays charged, and you never jump it, it's probably fine. |
Meter is good. And battery isn't charging so it seems. Anyway to test the generator ?
You are using the "DC" Scale aren't you....???
Starter / Generator test as found in the Technical Library..... S/G Test |
I used that link and went threw the steps. I got to were I jump a wire from the F terminal on the S/G. With the throttle opend all the way I was to hear the rpms drop some and the volt gauge move. But I didnt. Infact the RPMs went up and the volt meter didnt move. Quote:
Also note this. I do not have a key. I have one but its broken so im waiting for a new one. So the saftey switch isnt hooked up right now I have is jumper like this. On the ignition plug. Wire from green, to black and blue wires, then back out from those 2 to the solenoid. I have a toggle switch on the green wire to shut it off. Not sure if that will effect the charge any but its more info for you all. |
So with the RPMs actually going up you're saying its a bad S/G?
How tight is the belt supposed to be? Id say I have 1/2 belt movment. The S/G does spin though. |
| All times are GMT -4. The time now is 05:41 AM. |
