-   Tractor pullers using Cub Cadets! (https://www.onlycubcadets.net/forum/forumdisplay.php?f=12)
-   -   Engine problems (https://www.onlycubcadets.net/forum/showthread.php?t=27329)
brad.bristle99 09-15-2013 07:16 PM
Engine problems
I went to another pull this Saturday and did okay. But my engine wasent running the best. When I would idle it up all way it would pop quit often. I know it's not right but I am not sure what it is. Any ideas?
J-Mech 09-16-2013 12:23 AM
When you say "pop" I assume you mean backfire. Was it out the intake? Or exhaust? Backfiring through the intake indicates a lean condition. Out the exhaust, a rich condition. It also could be timing. Did it do it just idling? Or under load? More info please. :bigthink:
brad.bristle99 09-16-2013 07:17 AM
The backfire is comeing out of the exhaust. All I have done since last pull was adjust the idle and it ran fine for a while and then when I went to pull it started doing this. If it is timeing how do I tell?
J-Mech 09-16-2013 09:34 AM
Still need more info. What carb? Did you try adjusting the carb to get the backfire out? Start checking stuff. Where did you set the timing? Is it still where you set it? You won't know if it is a timing problem unless you check the timing. It is possible you even burnt an exhaust valve.
brad.bristle99 09-16-2013 03:56 PM
It's a standard Koehler 10 horse carb. I think Koehler 26 carb but not Sure. I have not tried adjusting the carb or the timing
dvogtvpe 09-16-2013 06:33 PM
when you have issues like that always go to the basics. did it get rained on? did you wash it before the pull?
brad.bristle99 09-16-2013 08:21 PM
Didn't get rained on or washed this time.
austin8214 09-16-2013 09:31 PM
You should have come and asked me Brad. I would have been glad to help.
