Loganvilledude |
08-27-2013 07:58 PM |
Mule drive pulley bearings
While I was cleaning the engine drive on the 122 I wiggled the two pulleys on the mule drive. One of them felt pretty tight and the other one is a little loose. I figured I may as well pull it out and see what it would take to replace the bearings. It appears the assembly is two shells that are riveted together so I can't tap the bearings out:bash2:.
Has anyone changed these out before? It looks simple enough to use the Dremel and cut the rivets off, split it open and get the bearing out / replace and rivet it back together, but I did a quick search on the bearings and nothing came up. So is it even worth it and should I just leave it alone?
