-   -   k301/ M12 question (https://www.onlycubcadets.net/forum/showthread.php?t=26696)
bocephus1991 08-18-2013 12:23 AM
k301/ M12 question
Long story short I have an old k301 with no pto clutch and a junk M12 will the pto clutch off the m12 fit the old k301? Both are k301 blocks . Are the clutchs different or are the cranks different? Looks like I am missing a sleeve or spacer the goes around the crank I think:bigthink:,sorry no pictures!
Mcamp 08-18-2013 07:58 AM
the old k301 has a 1in. crank, the m12 has a 1 1/8in. crank.
Sam Mac 08-18-2013 08:18 AM
Easy fix, you can get a bushing and key stock from McMaster Carr. You will need to cut a key way slot in the bushing.
6381K18 Alloy 932 (SAE 660) Bronze Sleeve Bearing, for 1" Shaft Diameter, 1-1/8" OD, 4" Length
98491A137 Zinc-Plated Steel Oversized Key Stock, 1/4" X 5/16", 12" Length
bocephus1991 08-18-2013 10:16 PM
Thanks Sam and Mcamp, fig someone would know!
