Conversion
Got a question that I was wondering....Can a 123 be converted to take on a Quick Attach undercarriage to retro fit a QA deck?:bigthink: I know that almost anything is possible, but I was wondering just how much trouble it would be to do it.
Cub Cadet 123 |
The "Quick Attach" feature is welded to the frame. Thus, you would have to (A) Cut one off a "QA" tractor, or (B) Fabricate this item, then......weld this to the underside of the frame.
Do you want to convert the 123 to QA or can a QA subframe be used on a 123? Roland has the answer. But you can use a QA subframe on a 123 but has to be bolted to the frame.:bigthink:
You should be able to use the QA deck subframe with your bolt on mule drive.
Cub Cadet 123 |
| All times are GMT -4. The time now is 09:49 AM. |
