Vanguard 14 hp - 18 hp Question
Hello Gentleman:
I Have A Vanguard 14hp V-Twin OHV, I broke a pushrod. From what I understand The 14hp & 18hp are the same engine except for the carburetors, True Or False? My question is : Can I use a 18hp head (used) and put it on a 14hp? Thank You In Advance! Cly |
What model of Cub are you working on...??
If you broke a pushrod, why are you wanting to change the head? Just curious.
*Sorry* Model 1440 & Change Head Because I Don't Have Tools To do oversize guides that got destroyed.
I would measure up the valves and the head bolt pattern. If they are the same go for it.
Briggs Vanguard 18hp v twin horizonal
Hello all, i would like some information on the driver for a v twin briggs. mounting it in a cub cadet 102 for a pulling tractor, need the hub that bolts to flywheel. any idea where to get one or do I need to make one !!!! thanks Tom
Try Midwest Super Cub, pretty sure they make one.
