-   -   1882 power steering box seal leaking (https://www.onlycubcadets.net/forum/showthread.php?t=25472)
dale c. 06-16-2013 08:10 PM
my 1882 steering shaft seal started leaking and I see in the parts breakdown that it's only available in a kit for $100.has anyone found a source for the seal by itself thanks dale
cub123 06-17-2013 06:01 AM
I ordered the kit from JD, it has a few extra seals just as a heads up. It was just shy of $60. The Deere number was AM107078. Your going to have to pull it apart so you may as well rebuild it. This is a good thing to read before pulling it apart. http://www.mytractorforum.com/showthread.php?t=208848
PaulS 06-17-2013 08:15 AM
I too repaired a 2072 with a kit for a JD. That kit cost less than $50.00 bucks and had all the seals needed and as already said had a couple extra seals but it stopped the leak. There may be purists that will only buy genuine cub parts but when one that takes care of the problem is available for about half the price I will take it. I also just bought a rear hydro seal. Cub wanted over $20 and I got the exact same seal from NAPA for just over $6.
Oak 06-17-2013 09:46 AM
I got the same kit from "The Green Parts Store" online, shipped to my door for $45. Looks like it's a little more now. Or if you have a Parker store near you their part number is SK000097.
http://www.greenpartstore.com/search...15&search.y=10
J-Mech 06-17-2013 11:09 AM
Parker as in the manufacturer of the hand pump right? ...... That's what I was going to say. Get me the numbers off the pump and I might be able to get a kit. If these are the Parker numbers I'll call my hydraulic supplier!
EricR 06-17-2013 06:44 PM
Jonathan, Oak is correct on the number as it is the same one we used on the 2072. And many others use the same.
J-Mech 06-17-2013 06:54 PM
Cool! I'll see what my supplier will sell them to me for. If it's a good price I'll list their information and everyone can use them!
Oak 06-17-2013 10:05 PM
I also have the 46 page service guide to rebuild these if anybody wants it. It is a PDF file so I can email it.
dale c. 06-18-2013 09:45 PM
thanks guys I just ordered 2 of them
