Ok, what did I mess up?
Got in a rush to change batteries in my 104 and I hooked up the battery terminals backwards:bash2:.....turned the key:bash2::bash2:.....now nothing at all.....no clicks or anything. So, because of my haste, what do I need to replace or fix?
Thanks in advance for your consideration, Cub Cadet 123 |
I don't think you messed anything up, you probably have a dirty conection somewhere that your missing, recheck and clean all your conections. It might be what your problem was in the first place and not the battery.:bigthink:
Since you heard "nothing", maybe you got lucky and had a bad connection(s). Connect the battery correctly, and try it out.
