Installed winch on a Cub Cadet 122
I'm using my Cub for hauling logs and firewood, and was frequently getting stuck. Finally decided to put a winch on for getting unstuck, as well as for extracting logs from hard to access places.
I decided to go with the SuperWinch 3000, which can draw up to 100 amps under full load. The small battery and generator on the Cub wouldn't be able to sustain heavy loads, so I built a battery box on the rear, and inserted a 125 Amp Hour marine deep cycle battery. I fabricated hitch receivers front and rear, and used 175 amp battery disconnects for the winch plug and receptacles. Here's the box. It's mounted on top of the hitch receiver, which is welded to a 1/4 plate that is bolted to the rear PTO base. http://tuna.rsnh.net/winchpics/BATTERYBOX.JPG Winch mounted on rear http://tuna.rsnh.net/winchpics/REARMOUNTED.JPG Here's the front hitch. I made a frame out of 2.5 x 2.5 x 1/4 angle and 1/4 plate. It's bolted to the 4 bolts holding the grill housing, and to the outside of the frame. It leaves just enough room to bolt the plow on. http://tuna.rsnh.net/winchpics/FRONTBRACKET.JPG Winch mounted on front. http://tuna.rsnh.net/winchpics/FRONTMOUNTED.JPG Another view of winch mounted on the front, as well as the 2.5 x 2.5 angle frame. http://tuna.rsnh.net/winchpics/FRONTMOUNTEDSIDEVIEW.JPG The switch is mounted on the left side of the pedestal. http://tuna.rsnh.net/winchpics/SWITCH.JPG The remote socket is mounted in the cigarette lighter hole. http://tuna.rsnh.net/winchpics/REMOTESOCKET.JPG My helper demonstrating the remote. http://tuna.rsnh.net/winchpics/HELPERWITHREMOTE.JPG When the winch is not being used it's stowed up out of the way. http://tuna.rsnh.net/winchpics/WINCHSTOWED.JPG My helper driving the Cub back to the house. http://tuna.rsnh.net/winchpics/HELPERDRIVINGITHOME.JPG |
I noticed the "helper' preferred creeper range low!! :bigthink:
Good looking custom winch. :popcorn: We will be waiting to see it pull a log!! :bigeyes: |
OUTSTANDING! Very well designed and made.
On a lighter side, your setup is great. I've been wanting to get a winch to play with. I just so happen to have a spare deep cycle battery as well. Great work, looks AWESOME!! |
Excellent workmanship! Thanks for showing us!
Looks great!
Nice work yodaddy :ThumbsUp: That will be real handy.
Wow. This is really something.
I just happen to have an extra winch in the garage somewhere... orphaned from a four-wheeler that got a better one. :bigthink: This has indeed sparked an idea... |
| All times are GMT -4. The time now is 12:23 PM. |
