-   -   First Cut with the 782 (https://www.onlycubcadets.net/forum/showthread.php?t=24302)
SGragg 04-30-2013 01:02 PM
Used my 782 to cut the yard with yesterday for the first time since buying it. Cut fine, even with a ratty 44" deck.
Noticed that the turning radius to the right is not as tight as it is to the left. Normal?
Lots of play in the steering wheel.
Need a rebuild of the steering box or just an arm linkage adjustment?
Thoughts?
vartz04 04-30-2013 01:12 PM
I'd just rebuild it its not hard. Also replace the tie rod ends and adjust them so it will turn stop to stop.
It cost me less than $50 to do the above on my 104 and the steering is great
Stem1415 04-30-2013 05:18 PM
steering gearbox needs a good re-pack with grease and possibly new bearings.
