-   -   1650 Shake (https://www.onlycubcadets.net/forum/showthread.php?t=24299)
Masmith 04-30-2013 08:46 AM
1650 Shake
This is the first Quietline I have ever owned or even seen running. With minor carb work I got it started. Starts very easy and seems to run fairly well with no smoke at all. When starting and idling the engine seems to shake more than I think it should. Is there an easy way to tell if the rubber mounts are bad without taking the engine out? The PTO switch is not moving. I am not familiar with the electric PTO/clutch at all. Not sure if the switch is just rusted or if I have a more serious problem. Good news is, when it is running the Hydro seems to work very good, but as with every hydro I have brought home, it needs a cork casket. That will be a rainy day project.
sawdustdad 04-30-2013 09:02 AM
Mine shakes, too, especially at idle. Tends to smooth out at full throttle. (I had the same question when I first started mine).
To move the PTO switch, pull the little handle up, then push forward. As for the iso mounts, you can look at them with a flashlight. If they are collapsed or cracked (as the probably are) you'll want to replace them.
_DX3_ 04-30-2013 09:17 AM
Yep those 1650's are known to shake pretty good at anything other than full throttle. I would check the drive line also. The rubber disks may need to be replaced and the front and rear drive shaft bushings probably need to be replaced also.
cubby102 04-30-2013 12:10 PM
Mine hardly shakes at idle to a quarter and from three quarters to full. Its uust got a mid range rattle to it. You get used to it over time . Its just the nature of the beast
drglinski 04-30-2013 05:49 PM
It's a big single piston engine. That's what they do.
