Niteblaster |
04-22-2013 05:21 AM |
lift strap measurement
I made my own and can't get the plow adjusted right. It is either set to dig the depth I want but then when I raise it at the end of a row it still drags on the ground. I raised it up about an 3/4th or a full inch and now it doesn't really run deep enough and at times like if I try putting my right tire in the lane just plowed it doesn't dig the ground at all. Just wondering the distance between upper and lower holes on the lift straps that you run on your set ups. I have the sleeve hitch mounted to the lowest of the 3 holes on the back of my 126.
