1650 steering wheel removal
Hmmm, now that I got the fenders off another goal is giving me fits. Is there a special puller for the steering wheel? That thing won't come off! :bash2: Suggestions?
:bigthink: Thanks, Nate |
Got a big brass drift??
Soak the shaft/nut w/WD-40 or whatever...for a while maybe? Put the seat back on and sit on it w/your knees crammed up under the wheel If Ya are a short wheelbase guy, Ya may need to shim up under yer feet w/2x4's or sumthin' back the nut off till its flush w/the top of the shaft set the drift on the nut/shaft put as much pressure up under the wheel w/your knees as possible and smack the drift w/a BFH Simple , huh?? Has Worked every time for me Unless Ya wanna spend big bucks for a puller ypu will probably only use once!! Dave S. |
Had the same problem with a 102 steering wheel. Soaked that thing for over a week but no luck. Another member, Matt G. shows a wood support that fits under the wheel and a wheel puller fits to it and I made one in about 10 minutes. Wheel popped right off. Made the price of the puller worth the cost.
To remove the steering wheel, remove the nut and spray pb blaster on the bolt and let it soak a few days. Then get a 5/8 fine thread nut and 4-6 inch fine thread 5/8 bolt. Screw the nut down half way on the the steering bolt then thread the 5/8 bolt till it bottoms out. Use a wrench to tighten the bolt / nut /steering. Using your knees under the wheel for lift, use a large hammer and hit the end of the bolt to jar the wheel free. You may have to do this a few times.Ifyou have no luck with that procedure use a 2x4 and slide it under the wheel on one side and the dash as the fulcrum hit the bolt again working your way around the wheel to lift. I had no problem with the 2x4 method. Totalcost $3.74 for grade 8 parts. This worked for me after I ruined my steering wheel with jaw puller. Avoid the jaw puller at all costs, that puller on the video hasn't been made in a while and I couldn't find one anywhere.good luck
When using a wheel puller do not screw the center bolt right to the end of the threaded shaft that holds the wheel. I used a piece of flat steel over the end of the steering col and then the center bolt of the puller on that. You never want to apply any pressure directly to the end of the steering shaft or it will either split or otherwise mess up the threads.
Thanks all I'm also a cub newbie I just passing on what I learned . Hopefully you don't ruin your wheel like I did
Thanks for the tips. Will give it a try.:beerchug:
| All times are GMT -4. The time now is 10:26 AM. |
