-   -   Finally got a chance... (https://www.onlycubcadets.net/forum/showthread.php?t=22702)
EarlJ 02-16-2013 10:23 PM
To get back on the 126 refurb. I built two electrolosis tanks and have a ton of small parts soaking. Tomorrow I will be making a makeshift tank to soak the frame, hood, rear and tower in. I don't necessarily want to strip the paint but really want to neutralize the rust and get the parts super clean so I can get some new color on them. I've used electrolosis for a while and it does a fabulous job cleaning the dirt and grease off the parts. They will be soaking at least a day or two. I'm really thinking on leaving them for 3 or 4 days as these are very nasty with surface rust and dirt. I'll try and get a pic tomorrow if I can remember...I can see some primer in the very near future...:popcorn::Woo:
sawdustdad 02-16-2013 10:28 PM
Please explain the electrolysis tank process for us newbies. Advantages/disadvantages, warnings, tips and tricks.
Thanks!
ACecil 02-16-2013 10:53 PM
Appreciate the update, Earl! Looking forward to your pics.
TheSaturnV 02-16-2013 10:57 PM
SSD, it works really well. The basic setup is a plastic tub to submerse the part you want cleaned and some rebar or other hunk of sacrificial steel. Dump in some washing soda (not baking) and hook up a one cable battery charger to the rebar and the other to the part. I cannot remember which is +|- . Google it, lots or tutorials on the net and even YouTube that spell out the specifics.
EarlJ 02-17-2013 01:08 PM
Negative goes to the parts to be cleaned positve to the sacrificial metal. Probably the biggest advantage is no dust. Also the amount of elbow grease used is minimal. You can use other chemicals in the bath but washing soda is safest, its not caustic and bio-degradeable. One disadvantage is setup time, ir takes a while to build a tank for large items but the bath can be used over and over again. The process neutalizes any rust on the parts turning the rust black. I still recommend a light sanding after rinsing and drying and be prepared to prime quickly as surface rust will form in just a few days
Methos 02-17-2013 02:24 PM
Thanks!
Here's some links for ya!
http://www.onlycubcadets.net/forum/s...ad.php?t=12500
http://www.onlycubcadets.net/forum/s...ad.php?t=12733
EarlJ 02-17-2013 05:51 PM
Epic fail
Spent the better part of the day building an extra large tank. I used a waterproof tarp for the liner. This tank will fit the hood, rear and frame so its perfect, with one exception. When i water tested all was good until about 1/4 full when the leaks started. Apparantly this old tarp isn't waterproof when it stretches. About 20 gallons of water had to be evacuated, so now i will venture off to lowes for a length of epdm pond liner. Hopefully soon i can start paint and reassembly..
ACecil 02-17-2013 09:50 PM
Thanks for the update and pic, Earl!
EarlJ 02-17-2013 11:01 PM
No problem Alan, the two coolers there are filled with small parts once I get the big tank set up I can stop using these. Hopefully by next week end I can start priming and painting...
JK777 02-18-2013 01:02 AM
What type of power supply are you using? And how many amps?
