-   -   clutch disc (https://www.onlycubcadets.net/forum/showthread.php?t=22384)
ngilson 01-30-2013 03:07 PM
clutch disc
hey guys been away for awhile. got a question for you need to put a clutch disc on the 106 . its being used for light pulling and more plowing any certian kind i should go for been looking at the aluminim one but figured it would were the pressure discs
:bigthink:
_DX3_ 01-30-2013 03:13 PM
Either the stock disk or a Kevlar disk and a blue spring with either one.
Kevlar link: http://www.midwestsupercub.net/clutch.pdf
Blue Spring link: http://www.cubclassics.com/pulling.html
cubcadet1650128 01-30-2013 03:18 PM
a kevlar would work and the aluminum wears way before the disk will i have a puller with a yellow spring and an aluminum disk and the disk is already gone with les then 5 hours on it. the plates are fine with getting a aluminum disk it would be best used with a stronger spring maybe a red one where it dosent tear at the bearing so much.
ngilson 01-30-2013 03:44 PM
thank:bash2:s bud that helped was going nuts trying to figure which rout to go. now mind stuff for the 72 puller i got to think what i want to do motor wise with that. thinking about 10hp with 12hp rod and maybe flatten cam down
eh idk
Merk 01-30-2013 05:00 PM
Check this topic out:
http://www.onlycubcadets.net/forum/s...ad.php?t=21799
The clutch set I talked about is in my 100. The engine is modified.
This set up is easy on your left leg and doesn't slip.
Donovan M. 01-30-2013 06:07 PM
how many lbs are the stock spring.
Merk 01-30-2013 06:19 PM
stock spring-200 to 225 pounds
blue spring-450-500 pounds
red spring-900 pounds
yellow spring-1100 pounds
