What happened to my "reverse" on my 782?
I parked my 782 back in July-August and finally got it started today, but when I did, there was no reverse whatsoever! I filled the transmission with fresh Hy-Tran and it has always had a really strong reverse before I parked it. Everything runs excellent on it, except no reverse. Could that be my hydro filter being clogged? Help-I've never experienced this kind of a setback before!!
Thanks in advance for your advice and interest in my thread, Cub Cadet 123 |
Sounds to me like one of your hydraulic dump valves is stuck.
Wow, thanks for the fast response Cubs-n-Bxrs! Ok, they are automatic dump valves, so how do I remedy that if it is the case?
Cub Cadet 123 |
To be sure that is the problem you can swap them and if after you swap them you don't have forward then it's time for new a new valve.
Bcdsfcret
:American Flag 1:
Take both of the valves out ant tap them on a hard surface on the nut end. Reinstall them and try your hydro. It should work just fine. I had one stick on one of my 782s and it has not done it since. Good luck. Brian |
Cub Cadet 123 |
Cub Cadet 123 |
Glad u got it figured out wouldn't have thought they would fly apart! Wow
A new one, or one that had been properly repaired would not have come apart. Several years ago I came up with a way to take them apart, replace the bad o ring, and properly weld them back together.
I was worried about sharing that information in fear that some one would not weld them correctly so I made sure to explain that if they came apart the parts could go into the hydro and cause major damage. I see a lot of people repairing them and advertising them for sale. I just hope they are doing the repair correctly. |
Maybe you don't know your own strength! Just tapped them too hard!
Anyway, if the PO had taken care of this tractor, you wouldn't have it now! |
| All times are GMT -4. The time now is 03:59 AM. |
