Engine builder
I am needing a engine for my 100. I found this site on the web Kustomsmallengine.com. Has anyone done business with this site?
engine builder
do a google ,and see what you come up with ,a complete rebuild will cost you ,around $300.00 too $500.00 in parts and labor ,if you have it bored and have the crank turned ,and valves done ,and head milled ,hope this helps .David
Engine
Well I don't have a complete engine
Just a block,head, flywheel,carb |
that is pretty cheap. I get $550 - 600 for a rebuild with aftermarket parts. that includes a crank grind, boring and valve seat cutting. OEM kohler stuff is getting pretty out of line with pricing
rebuild
Having my 10 hp Block bored out now at a machine shop for $35, if he can clean it up he will put a new sleeve in it and make it standard again, order undercut valve for $53 and new valve guides for $24 going to get a after market piston and gaskets for $59, we put it back together myself, the last rebuild was 7 years ago, not to bad for my puller with a LP Head and 18 hp cam at 4000 rpms. pull from 40 to 80 times a year
| All times are GMT -4. The time now is 03:18 AM. |
