steering column pops out of dash
My steering wheel on my 104 constantly pops out of the dash. Then it wobbles around all over the place. Is there a part that goes here that is just wore out or am I maybe missing something? It seems like the wheel is too high to lock into the collar coming through the dash.
3 Attachment(s)
I'm not sure if this is you problem, this is how I fixed mine from popping out, it was on a 1450. The hole was already in the frame from the factory. The clamp is a 2" muffler clamp with a bracket welded to it.
To fix that, the column should really be removed from the tractor, cleaned, tube re-expanded, and then loc-tited and retained with a pop rivet.
Thats what I figured needed to happen. Everythings gettin tore down in the spring so I will just deal with it til then as long as a little snow plowing won't destroy anything. |
That's a nice fix...I especially like the "no permanent mods done" method!
John Quote:
