-   -   Engine code is worn off on kohler. Need to know what carb kit to buy. (https://www.onlycubcadets.net/forum/showthread.php?t=19637)
bolivier 08-11-2012 05:50 PM
So I have a 1964 100 with what I assume is a kohler 10hp. Where it says what motor it is, the numbers are worn off. All I can read is the K. It has a walbro carb on it which is actiing up and I would like to rebuild it, but not sure what kit to purchase. Thanks for any responses.
Brent
David a Calkins 08-11-2012 06:41 PM
bad carb
i dont think you will be happy ,with a re built walbro ,i would look for a carter #26 or a #28 ,some people are happy with the walbro ,most are not
R Bedell 08-11-2012 09:03 PM
The Engine that came in the 100 was M/N: K241 - Spec: 46700
bolivier 08-11-2012 11:44 PM
Thank you
Brent
bolivier 08-13-2012 07:59 PM
my spec says 46280C????
