Change Tires
2 Attachment(s)
Has anybody tried these? I have a 1450 with the wider tires on it, but I would like to get the entire tractor under 36" Does anybody know if they would fit a 1450? They appear to have the same bolt pattern, but I am not sure how the off-set works.
Thanks, Charlie Surplus Centre Item# 1-3704 http://www.surpluscenter.com/item.as...catname=wheels 23X8.500-12 WHEEL AND TIRE ASSEMBLY New, CARLISLE TURF-MASTER tire on steel wheel with white finish. Made in the USA. Not for highway service. SPECIFICATIONS Size 23X8.50-12 O.D. 23" Tread Turf Tread Width 7-1/2" Mount 5 bolt on 4-1/2" B.C. w/ 2-15/16" pilot Backspace 4-3/4" Tubeless Pressure 22 PSI max. Ply Rating 4 Shpg. 32 lbs. |
I've ordered from surplus center before, some carlisle x-trac tire/rim combo and they are excellent, don't know about those if they would fit or not, but the company is legit.
Thanks gcbailey,
That's good to know, because that price almost seems too good to be true. |
