Removing my front PTO
How do i remove the front PTO on my cub 108. I want to take it off because this tractor is going to be a pulling tractor so don't need it.
Tthanks :IH Logo: |
This youtube video was made by a member here. It should show you everything you need to know to remove the PTO.
http://www.youtube.com/watch?v=7O4FE1tE_AM |
If i take my pto off what keeps the starter generator pulley on the crank is this pressed on and it wont come off if i take the pto off because i dont need the pto because of being a tractor puller thanks:bash2:
It is held on by a set screw. You will see once you get the pto off.
Just make sure the starter gen pulley is still tightened on the crank and you should be good to go :beerchug: |
Mine was run around for a very long time without a PTO clutch and did not have any problems.
You will be fine. The starter pulley won't come off when you pull the PTO off.
Here's another youtube video that I found. It shows set screw for the starter/generator pulley too.
http://www.youtube.com/watch?v=jUol4...eature=related |
