-   -   Best price on Quietline mounts? (https://www.onlycubcadets.net/forum/showthread.php?t=17821)
themaddhatter 05-11-2012 11:08 AM
Finally have some time to get into both of my 1450s, and they both need motor mounts (of course).
Been looking around the internet, and it looks like it is pretty common to find the new style OEM mounts for ~ $20 a corner.
Just wanted to check in and see if anyone has a source for a little better price (yeah, I am cheap).
Don't want to play roulette with the moog mounts, as I really hate doing something more than once (probably one of top 5 pet peeves).
Thanks in advance :)
dje22 05-11-2012 11:12 AM
You could save a little money by using all of your top mounts from both tractors on one tractor. Then get a new set for the other
themaddhatter 05-12-2012 01:35 PM
Thanks David for the tip!
I have pulled the engine, cradle & mounts out of one 1450, and the top ones don't really seem to get worked at all, while the bottoms are pancakes...
Didn't know the original mounts were the same top & bottom (mine were so mangled you couldn't really compare).
I have seem the pics of the "new" mounts, and those don't seem the same top & bottom. Correct?
dje22 05-12-2012 01:44 PM
Yeah the old ones can go on top or bottom. I used my top set and four more from another tractor last year when i did my mounts on my 1200. The new ones are shaped different. I dont think you can swap them top to bottom.
Methos 05-12-2012 03:55 PM
The bottom and tops are not the same.
racenitro 05-12-2012 08:24 PM
Don't forget to do the ISO Mount update. Weld the cross brace and your mounts will last a lot longer and you will not damage your mounting bolts int he pan...hopefully they are not already damaged.
CADplans 05-12-2012 09:23 PM
I just did my second one in a week!!
http://i1104.photobucket.com/albums/...010778x800.jpg
I think that little bar is the most valuable upgrade you can do to a QL!! :bigeyes:
When I unbolted the engine before I loosened the ISO mounts, the 2 bars just flopped down away from the engine!! :bigthink:
Who knows what kind of stress is on those 4 bolts holding the engine!!
themaddhatter 05-12-2012 10:13 PM
Already welded one up and painted it :biggrin2:
List still left on that tractor:
- Pull column & rebuild with bearing upgrades (once I get the damn steering wheel off
- Pinch the front axle pivot tight (sloppy right now). Have a bolt and nut, and will bend it back slooooooowly
- Fab new tubing tie rods & drag links & install with heim ends
- Install axle & new front tubed tires
- Replace plastic hydro fan (would love to do U-joint upgrade, but can't find any reasonable parts to do upgrade) :(
- Drop engine back in, fluids, drop tiller on it, and run it (got to get ground tilled for the wifey)
Then, I can basically do the same to the other 1450 (along with upgrading wiring as I did on the first one).
bkw3614 05-20-2012 11:35 AM
I have had the very same question lately, as I am about to bring a new used Cub Cadet 1250. I am new to the Cub Cadet world too, and would rather PLAY with the Cub Cadet than work on it. That being said, it looks like CC Specialties has a set of motor mounts that have worked well for others without the cost of the OEM part. I have surfed the net as well, looking for the answer, and this is the best price I have found.
I live in Minnesota, too. Now I want a 104, or similar gear drive machine. I am enjoying not taking my medication.
Methos 05-20-2012 12:16 PM
I wasn't happy with the MOOG mounts.:bash2: Went out paid for the cc ISO mounts and wasted time and $ on the MOOG mounts. I spent $25 more then the cc ISO mounts and twice the time and work.:TwoCents:
