-   -   Steering wheel removal (https://www.onlycubcadets.net/forum/showthread.php?t=17397)
aarolar 04-24-2012 07:41 PM
I am confused I am trying to remove my steering wheel and searching I found a few threads in the past about it however I don't have a nut holding my steering wheel on. I keep seeing references to removing a nut but I have no nut there is a bolt holding my steering wheel on so what gives?
model 124
jbrewer 04-24-2012 07:54 PM
Can you post a picture????
Pretty sure they all came with a nut.......
John
_DX3_ 04-24-2012 08:05 PM
Sounds like someone has had the nut off and didn't put it back on.
aarolar 04-24-2012 08:06 PM
http://i206.photobucket.com/albums/b...-02-11_648.jpg
http://i206.photobucket.com/albums/b...-02-04_576.jpg
aarolar 04-24-2012 08:07 PM
I thought that but I don't even see threads where you could put a nut?
David a Calkins 04-24-2012 08:11 PM
steering wheel removal
i bought a cub that ,some one did remove the threads ,they must have damaged the theads and cut them off ,so a ran a tap down to hold the wheel on ,so to get your wheel off ,you need to make a puller ,i seen tail pipe clamps used to grab with a puller ,,i made a split block ,to use with my puller ,and i mseen a guy use his knees to lift up on the wheel ,and tap the end on the shaft ,and the wheel did come off ,but you might damage the bearings in the steering box ,David
_DX3_ 04-24-2012 08:12 PM
I don't believe that is correct, but I'll let a NF expert chime in.
David a Calkins 04-24-2012 08:17 PM
remove the bolt part way ,and use a puller ,and make a split block ,even some hard wood will work,and c clamps to hold the block in place .David
aarolar 04-24-2012 08:37 PM
I tried this and no dice can yall better explain the puller your describing Im failing to see it in my head.
_DX3_ 04-24-2012 10:10 PM
Some links:
http://onlycubcadets.net/forum/showthread.php?t=2819
http://www.onlycubcadets.net/forum/s...ead.php?t=5772
