-   -   Hydraulic lift dimensions (https://www.onlycubcadets.net/forum/showthread.php?t=17367)
jlampe94 04-23-2012 06:06 PM
Was wondering if anyone had the stroke, and overall length of a lift cylinder open and closed, out a 782, 982, any of the wide frames that used the same cylinder. Been looking and not having any luck.
IACubCadet 04-23-2012 06:50 PM
Are the 1x9 series tractors the same as the later ones? I see you have a 149...you might be able to measure that if you have hydro lift on it...just a thought.
jlampe94 04-23-2012 09:02 PM
No there different from the looks, just dont know specs for sure. Looking to use the newer style one because it looks shorter overall and stronger for a top link on my 3pt.
mmzullo 04-24-2012 09:52 AM
82 series lift cylinder is different then the ql cylinders. stroke is different also. as for a wf to ql they are the same. Most of the parts are the same except for hydro lines and I think a lever or mount. cant remember .Look it up in the parts book
