-   -   Charge Indicator on a 123 (https://www.onlycubcadets.net/forum/showthread.php?t=16934)
Cubman 04-03-2012 08:54 AM
I own a 123 and want to put a charge indicator on it, but I don't know where it where it should go. I understand it was a dealer option, but I need a bracket or how to fabricate one and then where it should go. I have lights and a lighter and have not seen any pictures of where they were located. Thanks for the help.
IACubCadet 04-03-2012 11:33 AM
I have a 122 that has a charge indicator, but I know its not a factory or a dealer option. They took a hole saw and drilled a hole in the dash on the right hand side of the steering wheel...it looks pretty nice. But I know few people would want to drill holes in the dash.
Donovan M. 04-03-2012 01:48 PM
They were put right below the steering collum. And they were on there on there own bracket just like the ones you would put in your car.
TheSaturnV 04-03-2012 01:54 PM
I just sold a 122 that had the same done, on the driver's side of the dash. I don't think I would cut a hole in the dash, but it did look really good there and seemed perfectly logical as you could easily check it while changing oil, filters, etc.
cmatthew 04-03-2012 01:59 PM
factory installed on the left side of the console right above the tunnel. if you have lights. it mounts below the light switch.
Cubman 04-03-2012 03:07 PM
Thanks for the help guys. Does anyone know where I could get a bracket.
Yosemite Sam 04-03-2012 03:24 PM
Pretty sure cmatthew is right about the location of dealer add on amp guage.
I think I have one or two that are mounted there... But then again, I also have a 123 that someone cut a hole in the top of the hood and put it in there. Not really so sure a dealer did that though.
Ridgerunner97 04-03-2012 04:58 PM
My 123 has the bracket on the left side of the console hanging off the side above my left knee and it is original with the IH gauge set into it and the back of the gauge and wiring is exposed.
johncub7172 04-03-2012 05:20 PM
http://i41.tinypic.com/1zd6kj7.jpg[/:
This is what I done for a charge indicator on the model 71. Works great!
jbrewer 04-03-2012 06:39 PM
I like that! It's a nice safe place for it...
