-   -   1450 hydro upgrade question (https://www.onlycubcadets.net/forum/showthread.php?t=16260)
cavmedic 03-01-2012 08:17 PM
Picked up a complete front output setup tonight to add to my 1450. With it came the tower and also the directional lever.
My question is do I need to swap the whole tower and directional control lever when I switch the valve and add the second handle?
_DX3_ 03-01-2012 08:25 PM
You should be able to just swap the lever over to your existing tower.
cavmedic 03-01-2012 08:30 PM
Ok . I didn't study it , but the only difference I can possibly think of is the bushing that the lever/ levers go through on the right side of the tower / pedestal may be a bit bigger on the duals .
I need to replace the iso mounts , so when I pull the engine to put in the upgraded cradle and new mounts and cast iron oil pan , seems to be a good time to do the hydro upgrade also.
Cubcrazy 03-01-2012 08:32 PM
Alot easier putting in your lines to the front too when the engine is out.
cavmedic 03-01-2012 08:43 PM
That reminds me, I need to locate a picture of where exactly I have to punch through to exit them.
And have to decide if I want to "t" off that aux side and run a set of outputs to the rear in the event I ever want to use something that would hook up off the back.
Cubcrazy 03-01-2012 08:47 PM
I can get you measurements and a picture if you want.
Let me know.
cavmedic 03-01-2012 08:47 PM
If you wouldn't mind.
Cubcrazy 03-01-2012 08:54 PM
I will get picture and measurements tomorrow for you when I get off work.
cavmedic 03-01-2012 09:03 PM
That would be great , thanks.
Methos 03-01-2012 09:50 PM
Here's a pic but no measurements.:bash2:
