-   -   582 frozen rear end (https://www.onlycubcadets.net/forum/showthread.php?t=15461)
4SPEED 01-19-2012 04:10 PM
582 frozen rear end
this happened last year. and I cant find how the water is getting in.
the boot on the shifter is fine. and I dont have any gear oil leaking out on the garage floor in the summer. it does set outside most the time, under a tarp.
:bigthink:
http://i846.photobucket.com/albums/a...t/100_6809.jpg
thank God for Glycol , or the cast on the inside would be rusted. the cover plate was rusted and has some pitting.
http://i846.photobucket.com/albums/a...t/100_6811.jpg
Methos 01-19-2012 05:00 PM
Looks like you did a great job of getting it cleaned out.:beerchug: Are you using Hy-Tran? Moisture could be getting in thru the breather hole on top of the casting.
_DX3_ 01-19-2012 05:12 PM
You may want to remove the axles and pull the axle housings and drain out the sump of each housing. There is more than likely a good amount of contaminated fluid in those.
Attachment 19829
CADplans 01-19-2012 05:23 PM
Here is your enemy!!
http://en.wikipedia.org/wiki/Condensation
A shed that controls air exchange is the only answer,
or move to a dry climate!!
ACecil 01-19-2012 05:54 PM
Wow, that was frozen! Glad you got it cleaned out.
4SPEED 01-19-2012 05:59 PM
I thought that too. but it cant be . there was so much water in it the oil was coming out around the shifter.
I woud think any condensation would evaporate with each use in the summer.
as it warms up from use.
TEET 01-19-2012 06:00 PM
I agree with Methos...check your breather opening, or try to keep that area covered when storing if possible. It also looks like the gasket sealing your shifter assembly is leaking, sans the fluid shown in your pic running down, it may be entering around the bolt holes there. When was the last time you changes the hytran and filter? Perhaps its been like this for quite some time?
Good luck,
Jeff (teet)
4SPEED 01-19-2012 06:04 PM
Attachment 19829
I did jack it up , leaning it over . that did drain a lot of it out. im sure there is still some in it. its due for some work after winter. it needs a new brake and a paint job.
4SPEED 01-19-2012 06:07 PM
hytran and filter? OK new guy here... didnt know there was a filter in there.
_DX3_ 01-19-2012 06:10 PM
Your manual transmission doesn't have a filter, only the hydro's do. :beerchug:
