-   -   QA42 Thrower Question (https://www.onlycubcadets.net/forum/showthread.php?t=14632)
Jrobert 11-30-2011 01:02 AM
Hi, I was wondering if it was at all possible to be able to use the thrower with it about 1 & 1/2" above the ground. The drive being plowed is asphalt but very bumpy. Thanks!:bigthink:
ol'George 11-30-2011 07:17 AM
Yes,
but you might have to extend the shoes if they will not extend enough.
CC1650Dave 11-30-2011 09:47 AM
I've seen guys modify them to ride on small wheels mounted to the outside edges rather than the skids. If you had something set up like that, and made it adjustable, you could probably set your thrower to ride wherever you wanted it.
