Question
Does a loose throttle shaft cause a motor to rev up and down.:bigthink:
It sure can... sounds like you need a bushing.
Thanks Dwayne
Yep I sure do because its wiggling alot |
Is their suposed to be a bushing here already or is it a place to put one.
That's where i put mine. I think the Hillman part # for the bushing is 58087. If you have a good hardware store nearby that carries Hillman products they should have it. My local Ace hardware has them.
Someone correct me if that # isn't correct |
There were no original bushings and yes that is where you will press a bushing into.
Here is my thread on the part number and install: http://www.onlycubcadets.net/forum/s...ad.php?t=10329 |
| All times are GMT -4. The time now is 02:40 AM. |
