-   -   Wiring gremlin, Need Help! (https://www.onlycubcadets.net/forum/showthread.php?t=13992)
SwampRatt-1977 10-25-2011 05:08 PM
I'm just trying to test the engine, but I have no spark. Here is how I have it wired for a test fire. I am basing this off this video. http://www.youtube.com/watch?v=lfuSEie3rHM but for some reason I still have no park, everything is grounded. All suggestions are welcome (wiring GRRRRR):BlahBlah:
Matt G. 10-25-2011 05:09 PM
Bad switch? Bad wiring? Do you have 12V at the coil? Points clean? Coil, plug, and plug wire good?
CADplans 10-25-2011 05:13 PM
Yea, that!!
It is the condencer!!
Spelling must be correct for them to work.
R Bedell 10-25-2011 05:21 PM
but I have no spark
:bigthink:
How are you determining that...???
:HeadScratch:
CADplans 10-25-2011 05:29 PM
Originally Posted by R Bedell (Post 97769)
:bigthink:
:HeadScratch:
I do it by touching my tongue to the big black wire while the engine is cranking!!
R Bedell 10-25-2011 05:59 PM
I bet you do...:biggrin2:
SwampRatt-1977 10-25-2011 06:04 PM
i dont know if i have 12 volts at coil but the rest is all new points, condencer, coil, plug and plug wire.
Matt G. 10-25-2011 06:28 PM
Well, you need to find out if you or not...no amount of speculation on anyone's part is going to do any good if you don't check stuff.
New points need to be cleaned either with contact cleaner or by running some paper between them to remove any oily residue from the factory.
Onerook 10-26-2011 04:49 PM
Had the same problem with my 124 - I put a spark tester in line with the plug then went to checking connections. I found the switch connectors were "almost" clean, but not good enough. Small file and clean all connectors, switch terminals, and every connection worked wonders. When I hooked the battery back up :Explode: just right.
Sugarmaker 10-26-2011 10:04 PM
Matt is right on the oily points. I was not getting correct reading on OHM meter till I ran some paper through the points to remove the oil. Electrical is not my thing either.
Hope you get it figured out.
Regards,
Chris
