-   -   Steering gear commonality (https://www.onlycubcadets.net/forum/showthread.php?t=12452)
Duncan10072 08-01-2011 08:04 PM
Met a guy who needs a steering column for his CC100. I have 3 or 4 that came with a bunch of parts that I bought, my question is, are all the narrow frame ones the same and the wide frames the same or all they all the same for all of them except the original. I am going to look it up in the parts books tomorrow, but thought someone would know off the top of thier head. Thanks
Rod
Donovan M. 08-01-2011 08:11 PM
mesure them the shorter ones are narrow frame and the longer ones are for wide frame.
cub cadet people II 08-01-2011 08:13 PM
They are all the same except the original is different, the only difference is if you put a replacement column in it will be taller. If you put a original replacement back in it will be the same length.
Matt G. 08-01-2011 08:25 PM
I think there are at least 3 or 4 different lengths from 70 to 82 series. A 100 has a longer steering column than a 104, and both are NF tractors. I'm also fairly certain the 1x8/9/QL and 82 series are different, and different from either the 70/71/72/73/100 and the other NF models...
Duncan10072 08-01-2011 09:44 PM
Thanks everyone, I measured and I have 2 different lengths, and the narrow frame one is shorter and has like a collar around the top of it. Now I can help another new CC100 owner. He is new to the addition and I just want to help him out. I told him about this website so hopefully he will join soon. Thanks again for everyone's help
Rod
