Need help with Cub Cadet Original steering column
I am in the process of bringing a real nice un-molested Cub Original back to life. I have some questions on what the steering column mount should look like at the dash. I own 3 Originals and they are all different. I'm guessing someone had re-worked each of these before got them. Any help would be great. Thanks
Cub Original Steering Column
I have a ? about what the steering column should really look like where it comes thru the dash. I own 3 of these tractors and they are all different. Thanks Brian
Brian I merged these two threads for you.
Got pics of what yours looks like? :WWP: |
Cadet Original
I'm not real good with computers but hopefully I can get my daughters to help get some pics loaded soon. Wish me luck.
http://www.onlycubcadets.net/forum/s...ead.php?t=1024 |
Cub Original Steer Column
Thanks. So there isn't supposed to be anything holding the rubber bushing from coming out of the dash? One of the Cubs has a rivetted bracket around the column? Are the rubber bushings still available?
How's this
Great Pic But.......
I am interested in seeing a pic of where the column comes thru the actual "dash". WildBill actually explained what the rubber grommet will look like. But a pic of it installed would be super. I'm guessing that as the column bushings wore out on the Originals that I have, the PO's just "patched" that area. Thanks and hope to see pics. Brian
Thanks
I want to say thanks to everyone with a big thanks to WildBill. I would say as the rubber bushing wore out, PO's would just make a bracket to hold the column tube tight in the dash. This was probably easier than their failed attempts of removing the steering wheel. Well I hope to get the parts I need and get er up and driving. The IH part number you gave me should be available thru a Cub dealer I hope? Thanks again. Brian:Cub1:
| All times are GMT -4. The time now is 02:16 PM. |
