drive shaft removal?
1200, trying to replace the clutch and the manual just says remove the isolator and slide it out. I unbolted the isolator but can't get enough movement to get the shaft out of the ball. Am I just not pulling hard enough?
Thanks |
You need to unbolt the engine and slide it forward a bit.
