-   -   axle housing question (https://www.onlycubcadets.net/forum/showthread.php?t=11818)
riesedesperado6170 06-26-2011 09:06 PM
on the 1200 was the axle housing was it cast iron or aluminium?
_DX3_ 06-26-2011 09:28 PM
Cast Iron, Aluminum was not used till @ 1982 and newer on the cubs.
william1041200 06-26-2011 10:06 PM
I haven't really dug into it, but I believe my 1200 axle tubes are aluminum. That is my opinion based on paint chipped off near bolts, showing base metal. Its not Cast Iron, unless there is a trick base coating under the paint. My tractor has never never never been restored or modified before I got it. Also, I remember this question earlier this year coming up. I made a comment about putting my 100% cast iron rear from my prior 104 with higher 2nd gear in my 1200. That will likely be a project for next spring when Im dying to turn bolts.
