-   -   Best choice for front loader? (https://www.onlycubcadets.net/forum/showthread.php?t=11458)
Mooner 06-11-2011 05:26 PM
OK, not sure if this is the correct spot to post this thread, but I've been thinking I'd sure like to have a small tractor with a front loading bucket. Something easy to hook up would sure be a plus, too. Any suggestions? Cub or (whispering quietly) something else? :biggrin2:
Methos 06-11-2011 07:55 PM
I've had a Danco RD-1000 and now have a Kwik-Way and I really like the Kwik-Way!
http://www.onlycubcadets.net/forum/s...ead.php?t=9246
The Danco RD-2000 or RD-2149 are good choices but the Johnson and Kwik-Ways are easier to find. The RD-2000 is for NF's and the RD-2149 is for WF's. If you have the tools and cash the P.F. Engineering plans are awesome! It will cost you about $1500 and they have plans for a backhoe as well. Make sure that you get a loader that has the hyd rams on the bucket as well. Stay away from the Danco RD-1000 and RD-300. Both just lift the arms up and have a trip bucket. The RD-300 is the only loader that I know of that will mount on a O.
It will take about 30 mins to take the loader on and off but I would suggest keeping them on the tractor at all times. It gets old take them on and off again. A I've said before a FEL is my favorite attachment!
red56turbo 06-12-2011 12:13 AM
Well said Duke!!:beerchug:
I personally have a Johnson Loader and like it. It does what I need it to and was easy to mount on the 129. I agree with Duke,
have a dedicated cub with the loader. PITB to take off and on all the time. I've never used any other brand. I do like the fact the KwikWay's have self leveling buckets. You can still buy the KwikWay's brand new, too.
Yamaguy 06-12-2011 12:35 AM
If someone was to build a loader, is it possible to use the tractors hydro pump to run it? I am not sure if there would be enough hydro fluid to run everything. Just a thought I had because it would be nice to just plug it into the front ports and hit the lever to energize the loader circuit.
Methos 06-12-2011 09:33 AM
No not enough power to run the loader and you'd need more fluid as well.
Mooner 06-12-2011 02:13 PM
Thanks for the input, guys. Now...which tractor is the best choice for a front loader? :bigthink:
Methos 06-12-2011 02:22 PM
Depends on acouple of things. With Danco the controls were on the left side so I prefered the 122. With the Kwik-Way controls on the right I prefer a hydro.
Are you going to build a FEL or try and find a used one? Matt G has converted his Kwik-Way to his 682. (if memory serves me right) I think the wider the tractor the better. Better base then a NF.
Methos 06-12-2011 02:23 PM
Not all of the Kwik-Ways had the self leveling buckets but it's a great feature!
Mooner 06-12-2011 02:34 PM
At this point, I probably would be buying a loader. Actually, I'd like to find a tractor with loader combo. Is a 982 the best choice? How would it compare to JD or Kubota of comparable size?
Methos 06-12-2011 02:45 PM
A SGT would be a great choice for a laoder but they are pretty rare on SGT's. Papaglide has one on his super. Lets see if I can find pics for you.
