| inspectorudy |
05-29-2011 01:38 PM |
sleeve hitch and lift
3 Attachment(s)
I got my home made Brinley hitch on today and since I could no longer use my ball on the trans cover, I put it in the sleeve with a pull pin. Also I wanted to show you the lift I got at Harbor Freight that was made for a motorcycle but it fits my CC perfectly. It fits the front and the rear without any hang ups and it is the right colkor too! $79. It has the lift pads covered with rubber mats too so there want be any . It also has a built in mechanical safety stop that adjusts as you go higher, its the wire like device on top, and it is not hydraulic. This should eliminate jack stands without posing any risk.
