Piston rings gap K241
When looking at the ring gap specs for a K241, it shows .10/.20. Is this a range or are there two different specs for different applications? Thank you
Most likely just a wear range. Anything between .010 and .020 is good to run, anything over .020 and the ring needs replacing :beerchug:
----------thinking your omission of a zero, making it a hundred/two hundred thousand is a typo :bigthink: |
Yes. I typed it wrong. Thank you for the responses.
