-   -   Rebuilding my 100 (https://www.onlycubcadets.net/forum/showthread.php?t=7495)
Methos 08-07-2011 02:02 AM
Awesome pics Mike! She needs to go spend more time with mommy!:biggrin2:
scleve 08-07-2011 02:56 AM
Did you get a grade 5 or 8 threaded rod? Regular Threaded rod you just pick up at a Lowes or Home Depot or at a hardware store will not be strong enough to use as wheel studs. Will work for a while until you get in a bind and may just break. You can pick up wheel studs that will work at a autoparts store. Just My two cents.
_DX3_ 08-07-2011 10:53 AM
Shhhhh!!! He will be saying that soon enough... :biggrin2:
ACecil 08-07-2011 02:36 PM
Nice work, Mike! Thanks for the update! :beerchug:
litlmikeyl 10-04-2011 11:55 PM
Been holding out a bit...
3 Attachment(s)
My cub penny bank has been empty for a while now, so I haven't gotten much finished on my tractor with this whole getting married thing (which happened this last Saturday), but now that the big day is over I can get back on the horse and continue the project. As was suggested by another member, I put Grade 8 bolts in place of the wheel bolts and left them long enough to add a shaft to hang wheel weights on. Also got the motor mounted up an my engine stand so I can paint it soon.
Decided that I'll keep picking away at a full resto instead of getting it running and pulling it apart again to clean it up later. It'll make more sense to do it this way so I can do the mods I wanted w/o ruining new paint.
New pictures too... Enjoy.
CC1650Dave 10-05-2011 12:14 AM
What did you do with those wheel studs to keep them from turning when you tighten the lug nuts? I've been thinking about doing this myself, but the only thing I can figure is that I'd need to put a nut in between the wheel and the hub or weld the bolt heads to the hub.
Neither of which seems like a great idea...
Matt G. 10-05-2011 06:51 AM
You could put a lock washer under the bolt head, or use some loc-tite on the threads.
litlmikeyl 10-05-2011 10:48 AM
I used Permatex Red Loctite under the heads of the bolts. It's the stuff that requires heat to remove the fasteners when you wish to do so.
ACecil 10-05-2011 11:09 AM
Thanks for the update. Congrats on being married! :beerchug:
johncub7172 10-05-2011 11:30 PM
OK, guys. I didnot know untill I got my 100. I'am back at post 20-24. What if my welder was hot and went through? It was a mig with gas. I didnot drill and grind the crack as was suggusted. I ran a bead around any material I could, top and bottom. As I get set to grind my welds nice, I wonder if I should have drilled/grind?
