-   -   I was looking for a parts tractor... (https://www.onlycubcadets.net/forum/showthread.php?t=54085)
darkminion_17 01-13-2019 10:35 PM
That one is mine, maybe someone drilled it out, as that is the right part number.
Need a new shaft? PM me....
sorner 02-18-2019 10:14 PM
3 Attachment(s)
I got off this project for a bit while I took care of some other things. I started back into it because spring is around the corner and I want to use the sleeve hitch. We last left this project with some driveline issues. I was going to just replace the driveshaft. As it turns out the pump input shaft was pretty worn, and the trunion assembly was completely beaten to the point I don’t know if it could be fixed. So I decided to go a different way. I had a pump from an 1862 and a driveshaft from a 1211, and a driveshaft from a 2165 in the scrap heap. So I swapped the pump and made a driveshaft out of the two shafts. The rear part is 4” of the 2165 shaft mounted to the pump. The rest of the shaft is the 1211 shaft. The shaft slides into the inside of the 2165 shaft. It was really tight to get up inside though, and I welded it to the 1211 shaft. I had to cut about 5” off the 1211 shaft to get to the right length of 16.5”. The fan is a 123 fan too that’s missing a blade. I will put a new fan when I take it apart to do a restore on it after I make sure everything is working as I want it to. I did decide to put a window on the top of the tunnel to get at everything. I will make a cover to screw down to cover it. Also i am going with auto check valves rather than manual. So, pics?
Attachment 98437
Attachment 98438
Attachment 98439
jbrewer 02-19-2019 07:29 AM
Glad to see the progress!
Thanks for the pictures.
sorner 02-23-2019 02:07 PM
3 Attachment(s)
Driveshaft works good. But, engine not so much. It went BANG and died immediately. No compression at all. Broken rod I presume. :bash2: The oil is where it should be and looks good.
Edit: it made a window
Attachment 98510
Attachment 98511
Attachment 98512
darkminion_17 02-23-2019 06:12 PM
Sorry to hear about that, do you have another motor?
sorner 02-23-2019 06:17 PM
I do, but I’ve never seen it run. It is off the other 123 I stripped. It’s not as pretty externally but if it runs, fine. It feels like it has good compression. I never had one snap like that one. It melted the rod on the crank journal. I can see it through the window.
darkminion_17 02-23-2019 06:21 PM
Well, you have a spare at least. Keep us posted.
mortten 02-23-2019 06:44 PM
That sucks after all that work.
twoton 02-23-2019 07:20 PM
That's disappointing. Sorry to hear.
IHCubCadet147 02-23-2019 08:13 PM
Sorry to hear that, hopefully the other one runs.
