-   -   Got a model 70 to restore (https://www.onlycubcadets.net/forum/showthread.php?t=34666)
jeepchicken5000 09-28-2014 08:36 PM
maybe ill just stick to the sleeve hitch for now and see if I can sell the tiller for now
jeepchicken5000 09-29-2014 08:34 PM
6 Attachment(s)
well guys pure luck ran into a guy selling cub cadet weights short story got them for $120 great shape cleaned them up and painted them yellow to put on my 70 should look great also got a rear lift setup got the rest coming soon
jeepchicken5000 09-30-2014 07:51 PM
3 Attachment(s)
its getting close decals are on , rear lift is on and spring assist is in , needs the column and the Brinley adapter and a few more little things and good
johncub7172 10-01-2014 03:50 AM
Looking great! Your column is on its way!
:American Flag 1:
jeepchicken5000 10-01-2014 08:57 PM
well guys cut my lift rod for the 70 today made it 10 inches in length drilled a couple holes in it and put it on the hitch in back ill have pics tomorrow, also traded my buddy for his rear Brinley plow , needs paint but everything is there and even got the manual. Oh if you guys notice the puddle under the tractor my carb bowl was leaking some one had a flat aluminum washer on the bowl bolt I didn't take it off figured it would help seal, I took it off and now its dry. Ill need to get some of those rubber sleeves for the gas line and get a new sediment bowl which arrived today
jeepchicken5000 10-02-2014 09:21 PM
well still waiting on stuff got my rear brinly plow all painted up took it completely apart and went from there got a pic of my two brinly attachments looks great I want to drive it
bolivier 10-02-2014 10:22 PM
Everything looks great! Now that i'm back to work I don't have much time. Sure would like to paint some stuff.
Good job.
jeepchicken5000 10-03-2014 08:05 PM
4 Attachment(s)
well got it together and drove it around finally , how do I check charge off the starter gen not sure if its charging or if my older battery died finally
jeepchicken5000 10-04-2014 09:28 PM
I figured out my charge issue must have been a bad connection on the S/G works great charges fine now
IHinIN 10-05-2014 10:02 AM
Tractor looks great! It makes me want to paint my 100, but that will have to wait until after winter.
