Never did anything with one of these. A couple guys on WFM have done a couple Deere's from what I have been able to find out.
One of the other cub sites talked about this and had nothing but good things to say. I would love to see it mounted in an 82 series. My 782 is getting tired and it'll only be a plow/play tractor so I wouldn't have to worry about a pto.
The M18 I put in this spring is dumping MAJOR oil out from behind the flywheel. That means it has to come back out, to replace what i hope is the crank seal. I'm getting tired of dealing with it. I found a drawing for the driveshaft adapter, the thickness or length will most likely be different, but this is a start; http://i6.photobucket.com/albums/y24...ount%20001.gif I also found a coupon code that seems to work for 20% off; 12765822. I have a few people running the Predator generators and they run just fine. I will need to hook up the PTO as my 782 mows and snow throws both. If I pull the trigger, I'll start a thread on here, to show what is involved. |
If it it can be done and it works at $550 for a brand new engine it's a no brainer, I'd buy one tomorrow. Looking forward to your updates. :beerchug: |
Possibly hook an alternator up. |
And I wish there was an easy way to add on an alternator to our Cubs without a lot of fab work. If I had the extra amps to play with, I'd have a heater in my cab during the winter :biggrin2: |
Do we have any HVAC experts in here :bigthink: Somewhat more on topic, we have quite a few people here that can fabricate things, I think an adapter kit for the predator engines would be lucrative business. The driveshaft may require length adjustments as well. So a kit could contain the flywheel adapter, driveshaft, mounting plate adapter and any PTO adaptations needed. Anyone willing to invest $550 in an engine and put it all together? |
