-   Cub Cadet Lawn Tractor (LT) (https://www.onlycubcadets.net/forum/forumdisplay.php?f=42)
-   -   1320 Transmission Problems (https://www.onlycubcadets.net/forum/showthread.php?t=51416)
McGrew 04-16-2018 11:26 AM
J-Mech, From my very first post: . Two years ago, the hydro tranny started having problems when the splined couplers between the hydraulic unit and gearbox let go. I replaced the couplers, and we continued using it until the main input bevel gears lost all their teeth.
Ok, I did not give part numbers, but the fact that the couplers were replaced and no longer a problem seems clear. I think somewhere along the way, you and I got off on the wrong foot, and now your posts all seem condescending. I would like to put an end to that, as I have been nothing but cordial. Let me know what i’ve Done to offend you, and I will apologize. I do appreciate your expertise, and may need more help if those two gears are available.
J-Mech 04-16-2018 12:07 PM
You have done nothing to offend me. I have gotten frustrated with you, however, because we/I are trying to help you repair your tractor, but you were adamant that the parts were no longer available. When asked what parts you needed, you gave non existent part numbers and vague descriptions. We/I now understand you need input gears. That's a very simple answer, and I don't understand why after linking you to the manual it took so long to sort it out. You need not apologize to me, but in the future, please try to answer the question directly. We did, afterall, give you all the information and only needed a part number/call-out number and all you had to do was use the name listed that the parts book used. While previous rear history can be important, I think you gave too much focus to the replacement of the couplers (years ago) and that added to the confusion.
Moving forward: If you decide to try and repair the transmission, please follow advice given. Before ordering any parts, you need to remove, disassemble and inspect all the parts and make a list of what all is needed. Start a thread on the rebuild. (As a rebuild will be involved and a new thread under your name will make it easier to follow. ) If you have any questions about parts, post a picture. Pictures almost always totally eliminate confusion.
Good luck! :beerchug:
IHCubCadet147 05-03-2018 08:28 PM
My transmission is leaking around this little shaft thing (don't know correct name) as seen in the picture. Does anyone know a part number for the seal. And will I have to take the transmission apart to replace it?
zippy1 05-03-2018 11:24 PM
Here's the parts, from Cub Cadet. You should be able to find the numbers you are looking for.:beerchug:
http://www.cubcadet.com/equipment/AR...0-A/0024900010
IHCubCadet147 05-04-2018 09:44 PM
Thanks for the link.
