-   -   Upgrading a 782 to "super" status? (https://www.onlycubcadets.net/forum/showthread.php?t=17498)
MWShaw 05-14-2012 08:49 PM
4 Attachment(s)
Cub cadaver!
MWShaw 05-14-2012 08:51 PM
Getting down to bare bones.
MWShaw 05-21-2012 08:00 AM
Finished pulling the hydro valves and control levers of off the 2072.
Then pulled the steering column, sanded both assemblies down and painted them.
I need to get those installed on the 782, before the motor goes back in. I need new black rubber tips for the lift levers, this tractor sat near a house fire, the rubber was a little bit melted.
ACecil 05-21-2012 12:18 PM
You've been busy with the 2072! Please keep the pics coming.
maddog784 05-21-2012 12:25 PM
Have you thought about dipping them in the plasti-coat stuff? I was thinking about that for a set of levers I've got. Wonder if anyone's done that.
MWShaw 05-21-2012 12:45 PM
It may be worth a try? I have never used that stuf, but I know what your talking about.
maddog784 05-21-2012 12:59 PM
I've never used it either. My grandpa had some a few years ago, but it kinda slipped my mind until lately.
Gaden 05-21-2012 02:32 PM
I used that stuff on a bunch of tools many years ago, it worked great, you may have to dip several times to get the thickness you want.
As for the switch over, I see you're well into it, but it just seems to me if one were to go to all that trouble and expense it would be more reasonable to fix the 2072. I'm a recently new owner of an 1872 and have several flower beds to mow around, the power sterring and the hydro makes it an easy task, I personally have never driven a 782, but I can't see it being any more maneuverable.
MWShaw 05-21-2012 02:59 PM
Yeah, your thougths are the same as many others here.
This 2072 was very, very rough, it was way more work than I wanted to spend. The 782 was / is a real solid, low hour tractor, that I let get low on oil. My bad. I also have grown very fond of the 782, as I said earlier my only real compliant with it is the steering.
I was looking for the pieces to upgrade the 782 to power steering, when the 2072 came up. As good as it looks in the pictures, it is a parts tractor. Heck the engine was just sitting in it (as in not attached), and the P.O.s were using it that way:bigeyes::bigeyes: The only remaining engine bolt is holding on a mounting tab, that broke off of the cases.
Can it be fixed? Sure, just more effort than I want to spend, when the 782 is very close, to being whole again.
But really, you want to know the real truth as to why I parted the 2072 out????
Can you keep a secert????
Ok here it is.................the 2072 is not RED
LOL!!!!!!!!:beerchug::beerchug:
inspectorudy 05-21-2012 05:12 PM
Power steer that brute
Heck man, you already have the PS parts on the other tractor so all you have to do is install them. I added PS to my 1811 and cannot believe how easy it is to mow around all of the shrubs and flower beds my wife seems to throw in my way. All you will need is the front axle and the spindles along with the PS valve and hoses. You will have to do what I did and weld on an old straight shaft to the short PS valve shaft if your other mower has a tilt wheel. Do it before you reassemble the tractor that you are saving because it will be a whole lot easier.
