-   -   Let's See How You Get Your Cub Snow Ready? (https://www.onlycubcadets.net/forum/showthread.php?t=7178)
jbollis 01-01-2012 09:08 PM
Originally Posted by Cubcrazy (Post 108373)
Finally got the wheel weights installed on the 2072 so it is ready for snow duty. Chains on the tires and the tires are loaded. The 54" power angle Haban is ready!
Man that power angle would be nice. Maybe next year I will get that done.
ACecil 01-01-2012 10:45 PM
Looking good, Mike! :ThumbsUp:
TSWolf 01-01-2012 10:55 PM
Ok, I'm starting to get jealous now. I plow snow with my Ford 2N and Husqvarna LT, I think it's time to get a blade for the 109.
Cubcrazy 01-02-2012 09:08 AM
Yeah, you won't regret getting power angle Joe. They are sweet!!
Thanks Allen!
Diz Jr. 01-02-2012 09:34 AM
The weights and blade look great on the 2072 Cubcrazy :ThumbsUp:
Cubcrazy 01-02-2012 02:08 PM
Thanks Diz Jr!:beerchug:
Methos 01-02-2012 03:44 PM
Sweet pics and updates!
lilkrou 01-02-2012 10:39 PM
I am happier than a pig in the mud! I finally found the correct snow blade for my O and picked it up on Saturday. It did not have the lift rod, but it had another tab bolted onto the factory tab so I was able to jockey it around and use the lift rod for my BB36 thrower (no creeper assembly so I have not put it on yet) by using the tutorial that says to put the tractor up on some 2X4's and keep the blade on the ground to make the blade have the correct "float-range". Last thing to fabricate was the little clip-thing on the handle so that the blade would float. I cut a chunk out of the old rusty fence out back and bent it around until I was able to replicate the one's that one can find on the auction site. Fast forward to today, and we have thus far received 5-6" of snow and it is still snowing (lake effect snow for those of you who are looking at Indiana and not seeing any system stuff going through!) Lastly, I tried to push the snow with the ags on, but found that the 900' paved driveway with hills was a little too much so then I changed over to the standard tires with tire chains. That made things much better! Now, I see why you all fill your tires with fluid and put on a million pounds in order to help with traction! All in all, it was a fun and productive day off of work!
jeryan149 01-03-2012 10:39 PM
4 Attachment(s)
Last Season with the 149 in Canastota NY
Cub Cadet 123 01-03-2012 10:57 PM
Wow....now, after hearing of all the snow in Plymouth, IN and seeing the 149 in the snow, I'm really wishing we had enough to do something with. Just about 1" here, so I look out the window and I imagine it snowing while my cub gently weeps....:Sad:
