Todd, I hope you and the wall are fine today. Sorry to hear about your pto removal problems.:angry:
Todd,
Yikes, the PTO had you down for a little while. I have had problems with them too. I think those small set screws take roots in those deep threaded holes. Glad you got it apart. Regards, Chris |
6 Attachment(s)
Ok, PTO is off, you guys forgot to tell me (remind me) about the lock collar, before I beat the heck out of the pto trying to get it off!
Anyway after I cut the starter pulley to get the set screws out of the lock collar and starter pulley, and remembering to turn the lock collar I pounded the pto off and could get it into the drill press and drill out it's set screws. Finally! Also used a piece of cardboard to put the removed head bolts in so I wouldn't try and put them in the wrong spots. Also, I'm not going to be using this tractor for any pto driven attachments, so would I have to put the pto back on, or would it be a good idea to rebuild it and mount it anyway? If I wouldn't use it, what would go in it's place? Thanks |
Todd, before I forget it, there is a locking collar on the backside of the PTO bearing. Hope I'm not too late. :biggrin2:
Sorry I had to do that. rof |
Wow, glad you were on the ball DWayne:biggrin2:
What's your opinion on my question of the pto? |
I am not putting the PTO back on my nephew's 73. There won't be a reason for him to use it either. You can also leave off your PTO lever and release button arm. Just that much less to deal with. |
So I could use the pulley I buggered up? Just grind it down smooth, good to go?
Thanks DWayne:ThumbsUp:
